1010 clutch disk thickness
Jeff
01-30-2002 12:12:53
Does anyone know the thickness on a new or newly overhauled clutch disk of a 1010 series I have my disk out and the disk and pressure plate look ok can not decided to replace them or put it back together? Thanks
ChuckW
01-30-2002 12:58:06
 Re: 1010 clutch disk thickness in reply to Jeff , 01-30-2002 12:12:53
I wouldn't think that thickness has much meaning as long as the facing is good. The throw out bearing might be critical, but you free play adjustment should take care of slight wear to facings. I would be concerned that the pressure plate is in good shape and releases properly.
