Votlage regulator
Joe
02-11-2002 18:23:58
does anyone know where i can get a voltage regulator for an 12 volt altinator? I cant find any!
please help,
Joe
buckeye al
02-13-2002 15:06:06
 Re: votlage regulator in reply to Joe, 02-11-2002 18:23:58
Couple years ago repaired a friend's Oliver 1650 originally equipped with a Delco that used an external regulator. Regulator was bad. Went to NAPA. They didn't have a listing for Oliver tractors so I told them I needed one for a '67 Chevy half ton pickup truck. No problem! They claimed they only had listings for an all electronic regulator. The mechanical ones were no longer available. Maybe true, maybe not. Anyway, I used the electronic regulator but had to install a dash light to make it work. The electronic regulators a tickle of electricity to make them start working. A side marker lamp & socket between the ignition switch & if I remember right the I terminal of the regulator. Works fine.
John T
02-12-2002 07:21:40
Joe, what brand and type of alternator do you have?? The GM types (like SI - 10) mostly have internal regulation (which is why they are so polular in tractor conversions), while Chrysler and some Ford require an external dfevice. I agree NAPA would have one if you have the type and model number. Ol John T Nordhoff in Indiana
Mike
02-11-2002 18:43:56
Try NAPA
