JD 50 Powertrol oil
John Smith
02-16-2002 14:06:36
Can someone tell me what type of oil I need to put in my JD 50 to work the back hydraulic unit?
Thanks.
Mike C.
02-16-2002 22:38:42
 Re: JD 50 Powertrol oil in reply to John Smith, 02-16-2002 14:06:36
I use regular 10w-30 in my JD50 with no problems.
Mike C.
JD70Jim
02-16-2002 19:51:50
Mr. Smith
The Manual for my 730D and my 70g stipulate SAE 30 for 90*+ temperatures, 20-20W for 32*-90* and sae 10W below freezing, but you can also use good old HYGARD---just like what's in most of your newer JDs. These old hydraulic systems just don't care what you put in them and will work on either. I use HY-Gard because it's what I use in my 4020 and 3020 and I can use the same hydraulic cylinders on all of my equipment. If I want to disc with the 730D or the 70, I don't have to switch cylinders.
old bones
02-16-2002 15:44:06
been using deere's hydraulic fluid for years in my 49 A, 48 B. it's what they recommended, and it's been fine, hot or cold, easy or hard use. i figure they ought to know.
Frank
02-16-2002 14:41:53
John:
My manual for my 70D, as well as my '48 "A" said to add oil of the same weight and grade that you ran in the engine.
A lot of the folks say they use non-detergent in the Pow-R-Trol because they claim it foams less.
Frank
