Engine vibs on B
Joe
02-17-2002 15:32:36
in the last couple of days ive been feeling some vibrations quite bad on my B. I only drive it around my neighbor hood once and a while. What is causing these vibs.?
JohnDeere Fan
02-18-2002 13:35:16
 Re: engine vibs on B in reply to Joe, 02-17-2002 15:32:36
My A did that once, it was the clutch disk having cracked and gone warped.
Plus, if you've had it apart, make sure both flywheel and clutch disk's hub markings match the punches on the crankshaft, or it'll shake BAD.
Tractorboy
02-17-2002 16:03:32
Joe u better get to looking for a loose flywheel or worn splines on the clutch housing as this will cause it to get out of balance and vibrate . Hope this helps and give us more info .
Clooney
02-17-2002 15:55:25
Joe, what kind of vibration? What engine speed? In all gears? Does it happen sitting still? Hot/cold etc? Does engine run ok or have a matching miss? Clutch engaged/dis-engaged? Has it been apart lately?
~We will need more information to help you.
joe
02-18-2002 05:53:11
 Re: Re: engine vibs on B in reply to Clooney, 02-17-2002 15:55:25
all of those, hot-cold,in gear-out gear,standing still, moving.
Clooney
02-18-2002 15:44:47
 Re: Re: Re: engine vibs on B in reply to joe, 02-18-2002 05:53:11
Joe, does it have a miss to go with the vibration? If so repair that first, if not & you haven't had anything apart & it hasn't always had the vibration check for loose main bearings.
~If the vibration has always been there check for the flywheel to crank marks lined up & the clutch driver to crank lined up as well as the end play on the crankshaft.
~If the vibration is more of a bounce then check the tire pressure & for loose wheel bearings as that will allow the tractor to bounce with engine firing pulses.
