JD 530 -- fuel pump
John Henry
02-20-2002 08:26:48
My cousins 530 (gas) is leaking engine oil from over the fuel filter bowl. Crankcase oil level seems fine, and no noticible gasoline contamination in it. Any insight on what I should be looking for before I disassemble the bowl inlet assembly?
RLArmstrong
02-20-2002 08:36:26
 Re: JD 530 -- fuel pump in reply to John Henry, 02-20-2002 08:26:48
This is a fuel shut off system, if you have no oil pressure it shuts fuel off to save the engine. There are two diaphrams you need to replace. Its a piece of cake, unless the fuel tank is full. RLA
John Henry
02-20-2002 08:31:37
Fuel bowl assembly, not pump.
