1945 JD B Rear Wheels Question
Mike L.
02-28-2002 14:24:57
Are the pressed steel wheels supposed to be mounted with the dish out and hub clamps mounted on the inside?
Larry W.
03-01-2002 05:47:30
 Re: 1945 JD B Rear Wheels Question in reply to Mike L., 02-28-2002 14:24:57
Normally the hub and clamp are on the inside, so you can remove the tire and wheel instead of loosening and removing the hub. This also allows you the option of the greatest width. The only reason to put the hub out is to make the tractor "tipover" narrow.
Will P
02-28-2002 16:11:03
Like Tom said. They can go either way. Just depends on the tread width you want.
Will P
Tom
02-28-2002 15:21:19
You can mount them either way. It depends on your preference and the distance you want or need on the width of the rear tires. They are designed to go both ways.
Joe
02-28-2002 14:40:35
yes, the hub is on the inside.
