JD 60 float setting
John Hicks
02-28-2002 18:47:59
What is the float setting on a DTLX81 carb for a model 60. How do you measure it. Thanks Much for the info.
Mike Aylward
02-28-2002 20:11:15
 Re: JD 60 float setting in reply to John Hicks, 02-28-2002 18:47:59
John, the float is set at 3/8" from the bowl gasket surface, giving a wet fuel level right at the gasket. Hope this helps. Mike
Brian Davenport
09-09-2002 12:51:57
 Re: Re: JD 60 float setting in reply to Mike Aylward, 02-28-2002 20:11:15
Is that for a JD Model 60 gasoline carb?
Mike Aylward-typo, should be 3/4
03-02-2002 13:59:59
John, I made a typing error on my last post. The float should be set at 3/4" from the bowl gasket surface, not 3/8". The wet fuel level is the same. I apologize for any inconvenience this caused. Mike
