Power lift how to
36 A
03-03-2002 08:05:48
I plan to install a power lift on my 36 A and was wondering how the thing works.Is it like later models where the shaft gose up and down or dose this style rotate in a circle and us a trip to lower ilmplment.Want to install a mounted plow and culitavitor on it. thanks
Clooney
03-03-2002 09:15:57
 Re: power lift how to in reply to 36 A, 03-03-2002 08:05:48
36 A, the Power-Lift rotates the rock shafts just like the later power-trol. With arms attached to the rockshaft, the arms lift & lower whatever is attached to them. ~The big difference is; with the Power-Lift you only have all the way up or all the way down & nothing in between. With Power-Trol you have control to stop the rockshaft at any point you want & remote outlets also.
36 A
03-03-2002 19:22:47
 Re: Re: power lift how to in reply to Clooney, 03-03-2002 09:15:57
clooneyits for a B but i plan to put one on my a to can i put newer power trol on as well. the b is a 39 A is 36 .
