Powertroll
Joe
03-12-2002 12:30:25
how much does it cost to have the power trol unit rebuilt? mine leaks off with a load on it. and also, does any B havethe same bolt pattern?
Dave K (Fl)
03-12-2002 14:48:58
 Re: powertroll in reply to Joe, 03-12-2002 12:30:25
Mine was like that. I replaced the leather washer on the piston and the mentioned gasket. Works fine. Parts are cheap from JD takes some time to tear down and reassemble but I enjoyed doing it and just standard tools are required. It would be labor expensive to pay someone to do it. You do not need an engineering degree to do this but the parts book would help you a lot and the I&T manual.
Dave
JD70Jim
03-12-2002 12:39:44
As far as I know, the bolt pattern for powerlift and powertrol are the same for the A, B, G, 50, 60, and 70. I am assuming that you are refering to the "box" and not the rockshaft itself. I would think that a working one from any of those models, out of a salvage yard would be a cost effective alternative to rebuilding. There was an early powertrol which had different hose plugs than did the better, later version, but they still used the same bolt pattern.
Jon
03-12-2002 14:30:39
 Re: Re: powertroll in reply to JD70Jim, 03-12-2002 12:39:44
It's probably not the power trol or lift but the piston/cylinder in the rock shaft housing. Either the "cup" (which doubles as a piston ring) is bad or the gasket between the cylinder and the housing is blown. Not a fun job so it might be expensive if you farm it out.
JOE
03-12-2002 15:01:17
 Re: Re: Re: powertroll in reply to Jon, 03-12-2002 14:30:39
i know about all that, but i mean how much for the parts to rebuild it.
