Power LIFT
Joe
03-12-2002 15:03:49
i have a power lift on my b, when i push on the petals to lift it, it lifts(shakes quite a bit while lifting), but when it clicks is the up position, it goes back down, i have to do this several times to get it to stay up, whats wrong?
buckeye al
03-13-2002 14:13:53
 Re: power LIFT in reply to Joe, 03-12-2002 15:03:49
Are you sure you're not low on hydraulic oil?
Brandon
03-12-2002 20:41:27
I've never taken one apart, and I dare not claim to be an expert, but I believe that your lift has a rebuild in its future. It shouldn't shake, or go down (until you press the pedal again, at the top).
I think you at least need to put a new leather ring on the piston, I think the oil may be be bleeding past the ring, making jerky movement, and allowing it to settle after being raised. There may be other problems too.
If anyone has a better answer, please correct me!
Brandon
