1941 JD A piston clearance
Davey
03-16-2002 07:33:35
Anyone know where I can find the proper piston to cylinder clearance for a 1941 JD A with a
aftermarket gas / aluminum pistons .090 oversize??
Thanks for the help!!
Clooney
03-16-2002 16:27:23
 Re: 1941 JD A piston clearance in reply to Davey, 03-16-2002 07:33:35
Davey, you should really use the clearance dimensions furnished by the piston manufacturer, but lacking those the clearance would probably be somewhere around .006"-.008" vertical & .005"-.007" lateral at the piston skirt, but that depends on the cam grind of the piston & piston material alloy.
lynn
03-16-2002 13:17:51
Davey..right here..i would use .011 inch..a good way to check the clearance is to use a feeler guage right angle to the wrist pin on the rear of the piston and slide through the bore..make sure the piston is not real cold as this affects the clearance..lynn
