Just changed over to power troll, and have problems
Joe
03-16-2002 11:13:32
i just changed from power lift to power troll, and the bottom stud on the tractor isnt long enough to put a nut on it! i figured that it didnt have any oil going to it, so i filled it up, didnt leak and tried lifting it and when it got to the top, oil gushed out! can i buy a longer stud, or put rtv sealer around it? any other suggestions so i dont have to take the power troll back off?
Clooney
03-16-2002 16:18:43
 Re: just changed over to power troll, and have problems in reply to Joe, 03-16-2002 11:13:32
Joe, just use the studs & bolts that came out of the power-trol tractor that the power-trol came from & use the copper washer on the top right attachment.
~You are probably going to have to pull the power-trol back off anyhow, as there is a good chance you ruptured the gasket on the bottom without that stud being tight.
