HELP CLOONEY
jerry simpson
03-23-2002 16:36:58
THANKS FOR ALL YOUR PREVIOUS HELP. NOW 1939 H FRONT FAN HOUSING WITH THE PIPE THREAD PLUG ON TOP.WHAT KIND OF GREASE OR OIL AND HOW MUCH? AND WHERE DO YOU CHECK IT?
Clooney
03-23-2002 17:34:57
 Re: HELP CLOONEY in reply to jerry simpson, 03-23-2002 16:36:58
Jerry, if you are talking about the bearing housing right behind the fan? it should really be disassembled & the bearings cleaned, inspected & packed with high temp molly grease.
~Most people don't get that involved (it is quite a job) & just install a grease fitting & shoot some grease in, the amount depends on the discharge amount on your grease gun & how long it's been since it has been greased. ~If it has been a while maybe 5-8 pumps, then if after running it for a while grease starts to appear at the front seal, that was enough. If after a few hours of running grease doesn't appear, a few more pumps would be a good idea.
~Once grease appears don't grease it again for a year.
