1947 Model A PTO shaft housing
Mike Boyle
03-24-2002 19:25:14
I have had to replace the housing that goes around my tractors PTO shaft. It is a plate that the PTO shaft goes through and it houses two gears. When I removed the old unit from my tractor, I saw that there was no gasket between the housing and the rear end of the tractor. I am wondering if there ever was a gasket between these two parts and if there was, does anyone know where I might be able to get a replacement for it? I can make one myself, but I don't what to do that if it is not necessary.
Thank you,
Mike Boyle
boyle.6@osu.edu
Ryan
03-25-2002 07:31:36
 Re: 1947 Model A PTO shaft housing in reply to Mike Boyle, 03-24-2002 19:25:14
Mike,
The 2 gears you are talking about is your hydraluic pump. There is no gasket in there as the surfaces should be very close together so hydraulic oil will be forced though the pump in the Power-trol or Power-Lift. Do not wire brush these surfaces because that may scratch it upand cause it to leak.
Good Luck,
Ryan
Mike Boyle
03-25-2002 06:49:41
I really appreciate you looking this up for me!! For the time being I guess I will just put it all back together and see what happens. Hopefully it will not leak all over.
Mike
rollo
03-25-2002 04:57:58
I looked in the John Deere parts catalog and it does not show any gasket there. Maybe a little silicone seal would be good, or maybe you don't need anything. It's not under pressure.
JDBob
03-25-2002 10:06:18
 Re: Re: 1947 Model A PTO shaft housing in reply to rollo, 03-25-2002 04:57:58
There's no gasket in the PTO where you mention, as someone else said DON'T wire brush it.
When I do these I clean the surface with carb. cleaner, brake cleaner or whatever I have handy that will cut most anything, just prior to assy. I wipe the surfaces with laquer thinner and then pull all bolts up evenly. Never had a leak.
JDBob
t. hinton
03-25-2002 19:45:41
 Re: Re: Re: 1947 Model A PTO shaft housing in reply to JDBob, 03-25-2002 10:06:18
my 51 mod a was leaking in the same place (no gasket) i drained the oil cleaned the surface and used a little silicon and stoped the leak.
