JOHN DEERE H CARB
jerry simpson
03-27-2002 19:34:05
I HAVE A 1939 H dltx 26 carb fuel leaks from top of fuel bowl, carb has been over hauled, new needle and seat,gaskets , right float setting, good float,any ideas , thanks
jerry simpson
03-30-2002 05:34:18
 Re: JOHN DEERE H CARB in reply to jerry simpson, 03-27-2002 19:34:05
THANKS CLOONEY. I THINK I HAVE A POUROUS CASTING AFTER CLEANING, DO YOU KNOW HOW TO RESEAL IT , AND WHAT TO USE, AND DO I HAVE TO DISSASEBLE THE CARB AGAIN? OR CAN I LET IT GO AND EVENTUALLY IT WILL QUIT LEAKING, ITS NOT BAD WHEN THE ENGINE IS RUNNING. THANKS FOR ALL YOUR HELP, JERRY
Clooney
03-30-2002 08:06:03
 Re: Re: JOHN DEERE H CARB in reply to jerry simpson, 03-30-2002 05:34:18
Jerry, that depends on what part of the casting is porous, if it is a sealing area or flange, braze or a touch of weld, If it is a non-sealing area or just a pin hole, epoxy or LockTite 290 wicking casting porosity sealer will probably work.
~It must be clean & have no oil or dirt for either the epoxy or LocTite sealer to work.
~As for disassembling the carb, you will have to make that determination when you find the exact area that it is leaking from..... .....
Clooney
03-28-2002 03:47:53
Jerry, where exactly on the top of the fuel bowl does the fuel leak from?
~You could have anything from a porous casting to a plugged bowl vent to a leaking float to a leaking bowl gasket.
~To see where the fuel level is actually running, remove the carb drain on the bottom of the bowl then install a small barbed hose fitting, then install a 10"-12" piece of clear plastic hose on the fitting & wire it to run up next to the float bowl with the open end above the top of the carb. With the fuel turned on, the fuel level in the tube will be the same as in the float bowl. (leave the top of the hose open to atmosphere)
