466 head valves
Jim
12-09-2003 11:36:43
Does the exaust and intake both have valve seals? Also do they both get lubricated? Thanks
G-MAN
12-09-2003 13:37:56
 Re: 466 head valves in reply to Jim, 12-09-2003 11:36:43
The only 6466 engines that have ANY valve seals are the straight "D" models, that are not turboed or aftercooled, and those only have the o-rings on the intake valves. On turboed/turboed-aftercooled engines, intake seals are not necessary, because the positive pressure in the intake ports and manifold (boost pressure) prevents oil from migrating down the valve stems. The same holds true on the exhaust side, with the exhaust flow doing the same thing. The tight fit of the valves in the guides also helps control oil. I can find no application for the 466 that shows o-rings on the exhaust valves.
Gpower
12-09-2003 14:07:10
 Re: Re: 466 head valves in reply to G-MAN, 12-09-2003 13:37:56
G-man, check out the 4240.
Gpower
12-09-2003 14:23:44
 Re: Re: Re: 466 head valves in reply to Gpower, 12-09-2003 14:07:10
Only on the intakes..I see that now in your post...read it too fast.
GP
Gpower
12-09-2003 12:03:27
Yes they do, o-rings on the stems of both intake and exhaust. They do get some lubrication as well.
GP
