What is this JD tractor worth?
2zcreek
10-16-2003 17:34:16
I can send pictures. It is a JD model 40 but it has only ONE front wheel. According to the manual, it is a 40-T (for tricycle?). I have taken it apart and repaired it. It runs when it's together. Right now I've removed the engine for more work, but I'm tired of spending money and time on it. What is it worth?
How can I post a picture?
souNdguy
10-16-2003 20:55:02
 Re: What is this JD tractor worth? in reply to 2zcreek, 10-16-2003 17:34:16
The easiest way to post a pic, is to go to the tractor pics section on the left side, then choose add pic.. then give it the path through a browse windoe it gives you. pic size is limited to something like 100k.. but that is easy on a jpg.. etc.
Once uploaded it displays it for you... right click on it and choose properties, write down the path... i.e. Something like this... here is a pic I recently posted...
Link
Then get back to the discussion setion, type your message, and in the img url section, type that path out... then post the message.. should work fine.
Soundguy
