2010 alternator install
Eugene Tidmore
04-01-2002 18:14:46
I would like to have a wiring diagram for installing a 3 wire Delco alternator on a JD 2010
or as complete instructions as you have.
Jed
04-01-2002 20:12:33
 Re: 2010 alternator install in reply to Eugene Tidmore, 04-01-2002 18:14:46
I don't have a drawing but I can explain it to you. The single round post with the nut takes 12v constant with a heavier guaged wire. The two prongs that are together are wired as follows. The one marked ig, or possibly 1 is 12v keyed. The other is 12v constant. I am not sure about the 2010 but on the newer tractors The constant 12v wires went to a solenoid mounted on the firewall. The keyed wire went to the keyswitch.
