1970 JD 310 Backhoe--What engine?
Paul/NJ
04-05-2002 18:49:51
Hello,
Would anyone know what engine is in, what I was told a 1970 JD 310 backhoe and also where could I find the serial number on this machine?
How do I tell JD engines apart (219? or 276?)
thanks in advance,
paul
Brokenwrench
04-06-2002 05:39:44
 Re: 1970 JD 310 Backhoe--What engine? in reply to Paul/NJ, 04-05-2002 18:49:51
The 310 should be a 3 cylinder diesel. The 310a&310b had the four cylinder 219 engine. The engine serial no. plate is on the right side of the engine just below the head. The 219 engine has a verticle oil filter at the lower right front of the engine, the 276 has a horizontal oil filter half way up the engine on the right front attached to an oil cooler.
Paul/NJ
04-06-2002 08:17:49
 Re: Re: 1970 JD 310 Backhoe--What engine? in reply to Brokenwrench, 04-06-2002 05:39:44
Brokenwrench,
Would you know if a expanded rebuild kit for a 276 engine work in my three cylinder engine?
thanks,
paul
Paul/NJ
04-06-2002 06:36:49
Brokenwrench,
Thanks so much for the info.
Would you be able to tell me if there were different 3 cylinder engines and how to differentiate between the different models if there were any?
thanks again,
paul
