Coolant in Crankcase
joel
04-05-2002 22:05:42
I have a recently restored JD 420T. I had a slightly low oil pressure so I pulled the plug to drain the oil in preparation to add spacers to the pump. When I did, a gray milky oil came pouring out. I looked up in the crankcase and could see green drops on the crankshaft, rods, everything. The engine has recently been completely rebuilt. There was a hairline crack midway in cylinder wall #1 before I had it rebuilt so I had them sleeve it. Everything looked great and it has run great for the past 6 months. I pulled the head and cylinder #2 looked like new, cylinder #1 has a good bit of buildup but I have not had any white smoke. I cannot tell from inspection where the coolant is coming in. I would appreciate any advice. Thanks.
stan
04-06-2002 01:34:08
 Re: Coolant in Crankcase in reply to joel, 04-05-2002 22:05:42
I knwo how you feal about the anti freeze in the crankcase I had that happen to me after a rebuild on a allis chalmers m. What I would recommend is a product sold by napa auto parts stores its called Irontite. It is a chemical sealer you add to clean water. I have had good success with this. If you follow directions it should work
Mike F
04-06-2002 17:59:37
 Re: Re: Coolant in Crankcase in reply to stan, 04-06-2002 01:34:08
I would recommend k-w block sealer, you can get it at napa and most auto places, follow the directions to a T and it will work.
