12 volt generator not charging!
Joe again
04-09-2002 18:33:23
I guess you all know me now. My generator wont carge. ive tried all the tests over the regulator and nothing, maby just a tiny jump on the amp. gage. i put my digitol gage on the two posts on the generator when running at fast idel and nothing! does it need rebuilt??? This is a 12 volt negative ground with a new regulator. 1946 B
Clooney
04-09-2002 19:11:15
 Re: 12 volt generator not charging! in reply to Joe again, 04-09-2002 18:33:23
Joe, with that generator having been backfed powered there is no telling what happened to it. First lets go back to basics, you say it is a 12 volt system , does it have the original 6 volt generator on it yet, or has it been changed to a12 volt generator? ~Now lets test the generator; with the tractor running at wide open throttle, run a jumper wire from the (F) post on the generator (smaller post) to a good CLEAN ground spot on the generator or engine block (it MUST be a clean place without any paint or rust), then see if it charges, if no charge leave the field jumper wire on & then run a jumper wire from the (ARM) bigger of the 2 [posts] on the generator to the battery wire at the regulator, if it charges then, you have a bad regulator or regulator ground. If it still doesn't charge, make sure you have battery power to that battery wire (the one coming from the ammeter to the regulator) if that wire has battery power you have a bad generator (could be a burnt out armature due to the power backfeed or stuck brushes or ?). ~If at any time you have touched battery power to the (F) post on the generator or (Fld) terminal on the regulator you probably burnt the regulator out.
~Post back with any questions or findings..... ..... .....
Joe with some news
04-09-2002 19:20:35
 Re: Re: 12 volt generator not charging! in reply to Clooney, 04-09-2002 19:11:15
well, bad news, generator got burnt up, the points were stuck for about 4 hours! so i guess that done it! what does that cost to have it rebuilt?
Mark
04-10-2002 13:35:03
 Re: Re: Re: 12 volt generator not charging! in reply to Joe with some news, 04-09-2002 19:20:35
Email Kenneth @ classicgen@aol.com for estimate...
