1935 D Pistons
Marty Z
04-11-2002 00:00:34
I am just about to put the Cyl and pistons back together. Is it easier to put the Cyl. on first and then feed the pistons in . Or should I feed the pistons in from the bottom , and then bolt the Cyl. up with the the pistons already inserted.
Thanks Marty Z
Clooney
04-11-2002 03:29:38
 Re: 1935 D Pistons in reply to Marty Z, 04-11-2002 00:00:34
Marty, you can do it either way. On the "D" I personally install the cylinder block first due to weight & it seems easier to install the pistons with the cylinder bolted tight.
