How do i get sheetmetal off??
39B
04-14-2002 19:09:53
It has no muffler. All screws are loose. Do i need to remove the whole steering rod from the front pedistal and pull that out...then pull metal off or what. it is probably much easier than it seems but i am not doing good. Thanks sooo much!!! Please Help the best you can
easydoesit
04-14-2002 19:50:38
 Re: how do i get sheetmetal off?? in reply to 39B, 04-14-2002 19:09:53
Hey 39B, You do have to remove the steering rod to get the gas tank off.(Is this what you are having a question about?) You should get a maintenance manual if you are going far but I'll try to give you some info. Remove the nose cover, front grills, steering wheel and then slip the steering rod thru the front pedestal. Don't drop the bearings. Disconnect gas lines, choke and radiator shutter rods and gas tank support bolts and you should be able to lift off gas tank.I may have missed something but come back if it does't go right. Easy
easydoesit
04-14-2002 19:50:35
GLC
04-14-2002 19:35:10
Yes you will have to pull the stearing rod from the front pedstal. Then you have to unhook the gas lines. Then you can lift the hood and gas tank off.
Good luck Gary
jdman(MO)
04-14-2002 19:29:49
Revove Steering wheel, remove the 2 bolts from the steering housing, cap,bearing. Remove steering rod. Make sure the 2 bolts that hold the gas tank to the motor are out.. Also remove throttle rods,gas line to carb Lift hood over air cleaner.. Russ
