Shutter screws stuck for good!
Joe
04-17-2002 17:47:53
How am i supposta get these darn screws out??!! i need to put a new core in it and they must come out! i have soaked them in penitrating oil. they are philips, so if i try to get them out when there stuck, there gonna strip! what should i do?
Mikey G
04-18-2002 15:28:07
 Re: shutter screws stuck for good! in reply to Joe, 04-17-2002 17:47:53
Take the right size nut hold it over the screw head weld it on turn it out with a wrench. the welding heats the bolt to free it and the wrench is much nicer to turn.
Mikey G
Ralph
04-18-2002 08:20:43
Heat them with a propane torch, then give them a slosh of Blaster. Repeat. If you have an impact driver use that, or get a phillips and tap on the end with a hammer while twisting. If that doesn't get results, use a cold chisel at the circumference. I try and turn them both ways until they are loose. I believe persistent patience gets better results and takes less time than brute force.
JD JACK
04-17-2002 19:43:27
HEAT THEM UP. AND GET A IMPACT DRIVER. WORKS GREAT.
Will-Texas
04-17-2002 19:00:48
Heat the screw heads red hot with a torch...clamp on a good set of vice-grips and turn them out. They may need to be heated up more than once. Same with the rest of the bolts in the radiator. Those that twist off will usually leave a quarter inch nub...heat these again and use the vice-grips...those that don't come out this way (and some of them won't) drill out and re-tap.
Danny
04-17-2002 18:07:57
The ones in my 46 B were stuck too. I just knocked the heads off the screws and removed the shutters. Ground the ends of the bolts off flat with the surface, center punched them and drilled them out. Then retapped the holes for new screws. You may have no other choice.
What size drill bit? do you remember?
04-17-2002 18:12:22
 Re: Re: shutter screws stuck for good! in reply to Danny, 04-17-2002 18:07:57
sd
F-I-T
04-18-2002 13:24:33
 Re: Re: Re: shutter screws stuck for good! in reply to What size drill bit? do you remember?, 04-17-2002 18:12:22
I don't know what model tractor you're speaking about, but I checked the parts cd-rom for the new-styled "A", and those shutters were held on with 5/16" x 1/2" long bolts.
The standard drill size for a 5/16" tap is a size "F", which is .257" dia. If you had to, use a 1/4" bit, and let it wobble just a tad, and you'll have a suitable hole for 5/16" tap.
Frank-in-Tallahassee
70D // 855
