Removal of pin from fasteners...
Jerry
04-20-2002 16:28:32
I am prepping my hood and grille for painting and am wanting to remove the fasteners.....I cannot find an easy way to remove the pins from the fastener to get it out....any tips greatly appreciated.....Jerry
Clooney
04-21-2002 17:15:29
 Re: Removal of pin from fasteners... in reply to Jerry, 04-20-2002 16:28:32
Jerry, on the [Dubuque tractors] I drill a small hole in one jaw of a pair of vice grips then put the hole over the small pin & press the pin out by squezing the vice grips. ~If it the pins won't move easily in one direction just try the other direction. With the vice grips, those pins can be removed & replaced easily without damage.
Wayne in Tn.
04-20-2002 18:17:49
What model tractor are you working on? If it is like the Dubuque tractors, you can use a thick piece of metal with a small hole in it for a dolly, then use a hammer to drive the pin out. Are you sure you want them out? These cost $7 each at Deere.
Jerry
04-20-2002 19:05:18
 Re: Re: Removal of pin from fasteners... in reply to Wayne in Tn., 04-20-2002 18:17:49
Wayne, thanks....it is a 49 M....just thought it would be easier to clean up and paint if I had them removed first. Didn't realize they were that expensive....if I can clean up the main piece, thought I could replace the pins only.....good tip on removal.....
L.C.
04-20-2002 21:09:59
 Re: Re: Re: Removal of pin from fasteners... in reply to Jerry, 04-20-2002 19:05:18
The small cross pins are about $1 each, but Wayne's right about the stud and pin together costing over $7 each. I also tried to find an alternate source for the studs and pins without success.
Wayne in Tn.
04-21-2002 07:35:26
 Re: Re: Re: Re: Removal of pin from fasteners... in reply to L.C., 04-20-2002 21:09:59
A few months ago, I contacted Correct Connection and they said they had plans to reproduce the fastners at about 1/4 of the cost from Deere. But the last time I called, they still did not have them. I think they do have them for some of the other models.
