1951 jd b
idles but wont run at high rpm
Rudy in Texas
04-21-2002 11:07:41
Tractor idles but runs rough and backfires slighlty at high rpm. Carb has been professionally rebuilt, engine overhauled, new points plugs, condenser, head redone, compression on clyinders is 105 psi. Seems to be getting too much gas, plugs are fouled black. Tractor does not sm
walt
04-21-2002 13:30:33
 Re: 1951 jd b - idles but wont run at high rpm in reply to Rudy in Texas, 04-21-2002 11:07:41
I would check to air filter it could be that you have a restriction which could give you similar conditions.
