clooney
36 A
04-25-2002 17:45:33
No i found one on a tractor that has not run in about 10 years.just wondering if i can test anything or just put it on and try it.thanks
Clooney
04-25-2002 17:56:44
 Re: clooney in reply to 36 A, 04-25-2002 17:45:33
36 A, not much to test without a tractor hooked to it.
~You might want to replace the cylinder to housing gasket, piston packing, PTO shaft & pump seals, & replace the "o" rings in the two hose adapter ports as those are much easier before installing the unit.
~Make sure the valves aren't all rusted up & the hand lever moves freely.
