Engine knock
John L.
04-26-2002 20:30:23
I just bought a 730 diesel. Has good oil pressure, starts and runs good and has plenty of power. Problem is: It sounds like it has more of a knock to it when firing than others I've heard. What do you think?
david
04-26-2002 21:42:02
 Re: Engine knock in reply to John L., 04-26-2002 20:30:23
Check the flywheel to see if its loose. also you might check for a fuel knock i.e. the injectors,timing will also produce a knock, Hope this helps, David
John L.
05-01-2002 18:51:45
 Re: Re: Engine knock in reply to david, 04-26-2002 21:42:02
Thanks David
I'll pull the flywheel and check it for thightness.
