Clooney pto dont fit my tractor
36 A
04-27-2002 13:26:45
the pto cupler from the later A dont fit my 36 A pto inside the rear end.
36 A
04-27-2002 19:38:40
 Re: clooney pto dont fit my tractor in reply to 36 A, 04-27-2002 13:26:45
The shaft on the 36 must be about 1 1/8 or so . The one from the newer tractor is bigger. If there is going to be to much trouble ill put it on my 46 A.If this shaft will work on that one ill just do that.
Clooney
04-27-2002 15:03:08
36 A, exactly where is the match-up problem? At the front gear or at the actual coupling?
~What is the shaft number? [hopefully it is marked on the end of the shaft]
~What is the shaft length? ~Is the shaft the correct length, but just the spline size wrong? Or is there a length problem also?
~What is spline size on each end of the shaft? [maybe 1-1/8" or 1-3/8"]
~What size on each end of the shaft do you need to solve the problem?
~What size is the coupling spline?
~You have run into a problem that will require some research & fiddling to solve....
