2 bottom Deere plow
John Henry
04-30-2002 04:07:40
Where on the Deere plows do you find the model number stamped? Its a two bottom pull type, truss frame, 16 inch on steel. Points are hook-and-eye mounted not bolt ons. In pictures it looks like a number 77 but I,d like to be sure. Thanks
Will P
04-30-2002 04:26:59
 Re: 2 bottom Deere plow in reply to John Henry, 04-30-2002 04:07:40
They are not stamped with model numbers. Look for numbers on the plow beams and tell me what they are.
Will P
John Henry
04-30-2002 07:10:00
 Re: Re: 2 bottom Deere plow in reply to Will P, 04-30-2002 04:26:59
Thanks for the response. Looked it over well. Only numbers I found were on the cast moldboard mount AB-180. This raises another question. Didnt the truss frame design replace the conventional "curved beam" design? maybe thats why I cant find a beam number. Holler back when you can. Thanks for you insight, John Henry
Will P
04-30-2002 19:45:53
 Re: Re: Re: 2 bottom Deere plow in reply to John Henry, 04-30-2002 07:10:00
Yes the truss frame replaced the curved beam plow. Sounds like you have a 44 plow.
Will P
