Cooling fan bearing for a 49 M?
Jerry
05-02-2002 19:41:41
Have a big "wobble" in the fan spindle in my 49 M and took it apart to check it out....there is no evidence of a bearing in there, even though the spindle has a groove in it which looks like it was for a ring. Checked through the parts and it doesn't show a bearing that I can find....if there is one, does anyone have a John Deere number for it? Or, should I just put the thing back together and assume it will work? Thanks!!!! Jerry
mike
05-02-2002 19:49:13
 Re: Cooling fan bearing for a 49 M? in reply to Jerry, 05-02-2002 19:41:41
They didn't have bearings in them shaft just runs through casting. The aftermarket makes these fans. I haven't used one yet for a JD but did buy one for a Farmall A they look very similar but are not. Make sure you get the one made for the JD.
