1965 4020 John Deere Gas
Jim Hockemeyer
12-12-2003 14:24:47
Lookin' for some good tune up specs for a 65 4020 gas? I have no manual. What things do I need to know. Started working on this one for a neighbor guy. It runs very rough but compression is good. Got all new ignition parts but I just wanted some direction on the settings.
Mr. Green
12-12-2003 15:07:43
 Re: 1965 4020 John Deere Gas in reply to Jim Hockemeyer, 12-12-2003 14:24:47
I'll be happy to help you. I have a 1966 4020 gas.
Distributor point gap 0.016 Spark plug gap 0.025
Timing (at 2000 rpm) 20º BTDC
Firing order 1-5-3-6-2-4
Jim Hockemeyer
12-13-2003 06:16:43
 Re: Re: 1965 4020 John Deere Gas in reply to Mr. Green, 12-12-2003 15:07:43
Thanks for your help!
G-MAN
12-13-2003 12:03:55
 Re: Re: Re: 1965 4020 John Deere Gas in reply to Jim Hockemeyer, 12-13-2003 06:16:43
If he's going to be using it often, and wants to drastically improve starting and performance, I'd recommend installing a Pertronix electronic-ignition set-up. They're not terribly expensive, are easily available through most auto-parts stores (go prepared with the polarity of the system (positive- or negative-ground), the make and model of tractor, and if possible, the distributor part number). They come with good instructions, and will really improve starting and response, thanks to a hotter spart. And they eleminate having to worry about point problems in the future. Money well spent, IMHO.
