John Deere 50 power shaft clutch adjustment
John Hicks
05-19-2002 18:48:46
I wanted to check the adjustment on the PTO clutch and have noticed that one book I have says to set it at .090 and the other at .060 between the brake plate facing and the flange of the cam disk. Which clearance is corect. Thanks for the info. John
F-I-T
05-20-2002 06:46:36
 Re: John Deere 50 power shaft clutch adjustment in reply to John Hicks, 05-19-2002 18:48:46
John:
I have always used .090". Both JD and I T always said you could use a 3/32" welding wire also (0.09375").
Frank-in-Tallahassee
70D // 855
