'29 D hits on one
Don E. Foster
05-28-2002 07:33:17
Hits on one. Boy does it idle nice, can count the bangs!!!! Have been told that mud daubers can screw things up through a breather hole. It's a WICO (not the original). How can I check this out without messing everything up. I'm not a mag man!!!!
GORD
05-29-2002 11:16:30
 Re: '29 D hits on one in reply to Don E. Foster, 05-28-2002 07:33:17
Check the static timing on the flywheel to be sure it is timed right. When the tractor is running-remove the spark plug wire one at a time to be sure that both cylinders are firing. Also check the spark strength on both cylinders. Make sure that you are not using Champion spark plugs!
I have a 29 D that will not run on any new Champion plugs. Also check the point gap in the mag.
JDM Guy
05-28-2002 12:53:45
When a Deere "hits on one" it makes a funny noise. Some times they make that noise but there running on two cylinders. I don't know why that is. My M did that in cold weather but idled fine. Hope you get it running.
Jerry S
05-28-2002 10:40:10
If you suspect it has an airflow problem, like Clooney says, take the air pipe off the front of the carb and see if that makes a difference. Rules out airflow if you still get the problem. If no change, swap plugs from side to side & evaluate. If no change swap plug wires to see. If nothing is helping or changing the problem, then post for more help.
Bob-Wyo
05-28-2002 08:26:29
Don does it hit on #2 when you open the throttle or put it under load? if it does it's probaley running normal. Give us a little more info and post back.
Bob
