FIT's lye gravy worked with a twist
Jerry S
05-28-2002 11:03:25
I went from the post from Frank some weeks ago and it went well. I did something that Frank didn't say he tried but it helped. I put 12 cups of water in a dutch oven and used 24 tablespoons of corn starch. I mixed the corn starch in a smaller pitcher with some of the 12 cups of water first till it stirred in completely. I then cooked it til boiling like I was making gravy. I let it cool down and transferred it to a plastic bucket. I poured in about 2/3 to 3/4 of a pint size or so of Red devil lye. I stirred it in a little at a time. That method makes the starch solution get hot. I liberally painted this onto the A and it covered most of the tractor and I had about $5 into the stripper. I kept it in the barn overnight and it rained which helped keep it more moist but I should have covered it in plastic. THe heat from the reaction keeps drying the paste out. I hosed her off in the driveway the next morning and scraped most all the paint off. Frank, if you are reading this, you mentioned having trouble with lumps. Using this method, I had no issue with lumps and I had an excellent adhesion even to vertical parts. I think the lumps you get are a result of the heat pockets you get from the lye making an area of the solution hot before the starch is set. Gravy starches are a hot set starch so the cooking will tie up a lot of water per unit starch once it is set. I knew that food science degree would come in handy sometime. Thanks for the ideas on this one FIT.
F-I-T
05-28-2002 12:19:25
 Re: FIT's lye gravy worked with a twist in reply to Jerry S, 05-28-2002 11:03:25
Jerry:
Good deal ! I'm glad you not only got your tractor clean, but you improved on the recipe as well ! Down here in Florida, because it's generally sunny and pretty warm, I had to keep misting it with a lye-water filled garden sprayer. It works very well on the original JD paint. Newer acylic enamels are quite a bit tougher.
Did you have a chance to try a pressure washer on it ? That worked really well for me.
Frank-in-Tallahassee
70D // 855
SEAMO
05-28-2002 18:39:02
 Re: Re: FIT's lye gravy worked with a twist in reply to F-I-T, 05-28-2002 12:19:25
F.I.T. Do you have to spray any thing on the tractor to neutralize the lye such as baking soda? Also how many differnt kinds of lye are there? Thank You Earl
F-I-T
05-28-2002 19:35:01
 Re: Re: Re: FIT's lye gravy worked with a twist in reply to SEAMO, 05-28-2002 18:39:02
Seamo:
Lye is the common name for Sodium Hydroxide, NaOH. We call it lye just as we call Sodium Bicarbonate, Baking Soda, or Sodium Carbonate, Washing Soda.
Lye is a strong base. If you felt the need to neutralize it, you would use a lot of weak acid, like vinegar (acetic acid). I don't see the need to neutralize it, just rinse afterward with plenty of water. The test for this would be to catch some of the rinse water and check the pH (if significantly over say 8.0 or so you still have some base on the machine). It rinses off very well, and comes off even faster if you spray a little soap on the area being cleaned as the soap bubbles help wash it away.
You won't have any problems at all if you just rinse it off thoroughly.
As far as lye types, you can get NaOH in aqueous form (already dissolved in water...expensive !), flake form or crystal form. If you use a lot of it, you can buy it in 100# cans of flakes, but I buy it in 1# cans at the supermarket for about $3.00 ea. Red Devil is a fairly well known brand. You can also find it at most good hardware stores.
70D // 855
Rod
05-28-2002 13:01:52
If you rinse it off on the drive, does the lye affect the concrete in any way?
F-I-T
05-28-2002 13:19:47
 Re: Re: Re: FIT's lye gravy worked with a twist in reply to Rod, 05-28-2002 13:01:52
Rod:
I use it all the time to clean the oil spots off the concrete, and I haven't ever seen it cause any problem with the surface. It's pretty benign stuff once you dilute it.
F-I-T
Jerry S
05-28-2002 12:37:26
I don't have a pressure washer. I do have 3 teenage boys and an 11 year old boy so elbow grease is occasionally available. I thought about renting a pressure washer if I can't get the grime off. So far, it took grease, paint, and primer pretty well all the way. Some paint that earlier didn't peel ended up peeling after I did the washing. I am also very interested in how you do your painting on your slick 70. I haven't painted before and don't have much for paint tools so I thought about doing some cast parts by hand with some hardener and a little thinner in JD paint then let a pro do the sheet metal. Maybe you have some good tricks I can learn from.
F-I-T
05-28-2002 13:17:16
 Re: Re: Re: FIT's lye gravy worked with a twist in reply to Jerry S, 05-28-2002 12:37:26
Jerry:
As far as the painting goes, I did it myself with acrylic enamel. It is definately more expensive than JD paint, but I wanted something that would not get dull too quickly in the horrific sun we get down here. I painted some parts of my 855 (hood, side shields, etc.) using JD paint and hardener about four years ago, and that paint is very dull now. I just finished putting some of the acrylic enamel on the 855 hood, then clear coated it for UV protection. The 855 is probably my next painting project.
I'm certainly not a pro painter, and this has been a great learning experience for me. Since I had the tractor in so many pieces, I painted those pieces one part or assembly at a time, so that when they were together, I wouldn't have any unpainted area that I could not reach with the gun. I had an older cheap gun, and a newer HVLP, as well as a small trim gun for the project. I don't know that I will ever get the hang of the HVLP.
I primed every surface with a good quality (read expensive !) epoxy primer. I think a good primner for bare metal areas is one of the keys to get good adhesion and long paint life. I also used a high-build primer on the sheet metal so that I could sand and blend out minor pits. Some folks say that the high-build can shrink, and I didn't use too much of it so we'll have to see. I still had to wet sand a few miscues, bugs and runs. Then I ran the tractor, fixed a few leaks, washed it thoroughly, then applied a finish coat. I did rough it up and clear coated the finish to protect it from the sun. I like the look of the clear. Time will tell if I made a wise choice there.
If you can get your hands on a small compressor and a low end gun, you can do a respectable job on the cast parts of the tractor. Your idea of finding someone to do the tin work will work fine, too. JD paint is very easy to work with, but understand that it may dull before other auto type coatings. Thinned paint with hardener can be applied with a good bristle brush, too, and it will look fine. You can cover a lot of cast iron that way, but a gun is just so much faster.
You have to right idea in that cleaning is the key !
70D // 855
Good luck
