1943 John Deere AR crank movement
Rich Morris
05-31-2002 07:32:44
Hi On my AR the crank flywheel will move side to side about 3/16" is there a thrust washer or a adjustment for this. Also how do you check the engine oil level I can find no dipstick & do not want to start it because if this. How many quarts of oil & what grade & weight do I use in this unit.
Thank You! Rich
Walt in Jaxn, Tn.
05-31-2002 12:17:16
 Re: 1943 John Deere AR crank movement in reply to Rich Morris, 05-31-2002 07:32:44
what year model? i'm supposing the flywheel is exposed? with the tractor sitting on a fairly level spot (you don't have to have the spot surveyed, just not on an obviously steep hill side), look below the flywheel and forward or below the clutch pulley and forward and you will see a long hex petcock with holes in the side, turn the capscrew counterclockwise two complete turns and oil should start dripping out the holes before you get the wrench off, if not, remove the capscrew and poke a piece of baling wire in the hole to make sure the hole is not plugged up, put the capscrew back in and back it off two turns, then there will be a stack on top of the crankcase with a mushroom shaped top. it will have coil spring clips holding it on. take it off and remove the filter inside that has what looks like wire mesh with straw inside. pour oil in the hole slowly until the oil starts to run out the petcock, then close the capscrew on the petcock, snug, use the same oil you use in your car for now til you get the engine started, then you can decide what oil to use later. as for the side to side play in the crankshaft, that can wait for later too. do you know how to use the clutch?-----walt
