1945 B
Elkhorn Denny
06-09-2002 06:21:01
My 1945 B sat in the shed for years. I could only get it started with ether. After doing a cylinder leakage test, I found out the minimum was a valve job (found out the valve seats were pitted I think from sitting).
The right cylinder wall is pitted at the top 1.5 inches. I think that should be ok. The top ring on both pistons are missing, which is very strange.
The machine was rebuilt and seems to have very little wear.
I think the best thing to do is rering the pistons and slap her back together and see how it runs????? ?????
Tractorboy
06-09-2002 17:26:30
 Re: 1945 B in reply to Elkhorn Denny, 06-09-2002 06:21:01
It sounds to me that you are not getting enough fuel or enough spark to start it . These old motors dont have to be right up on everything to start easy but they do need to have plenty of fuel and spark . My 2 cents worth
Ravgardner
06-10-2002 05:06:07
 Re: Re: 1945 B in reply to Tractorboy, 06-09-2002 17:26:30
You may not be missing the top ring. My 44 B pistons have what I think is called a Carbon collector on the top of the piston. It looks like a ring slot, but is suppose to collect carbon and help the piston is some way. Perhaps cool the piston.
Frank M.
06-10-2002 17:32:58
 Re: Re: Re: 1945 B in reply to Ravgardner, 06-10-2002 05:06:07
I wondered about that on my H. It has the empty groove at the top of the piston too.
