My B started burning antifreez
Joe
06-10-2002 17:03:05
I had my 1946 B tractor apart putting in a new clutch and replaced all the oil seals in the hydrolics and in the axel. it sat for about a month(longest its sat since i owned it)started it after turning over twice, filled my garage up with thick white smoke! it smelled like something sweet. Very good smell, but gave me a frown. Im hopping it just has a leaky head gasket, NOT A CRACKED HEAD! how can i test this? i just spent all my money on all these recent gasket and oil seal replacements. so it would be sometime before i can get to that. But anyway after it ran for about 2 minutes the white smoke cleared up. it also didnt run too good during that time. What shoul i do?
shoe
06-10-2002 22:52:28
 Re: My B started burning antifreez in reply to Joe, 06-10-2002 17:03:05
Not anything serious, you have a head gasket leak-
ing. The antifreeze is seeping into the cylinders
and you are burning it with the gas, maybe just
a re torque of the head will fix, might try it.
Ron
06-10-2002 19:41:45
I am shure you are positive about the smell, But I have had problems with MUD Daubers building nests in the air intake.... When they break loose, they fall into the elbow, and block the intake pipe.....Makes it Smoke terrible..... FWIW..... !!
Tractorboy
06-10-2002 18:27:54
Joe it may be the pushrod tubes
farmboy
06-10-2002 18:38:47
 Re: Re: My B started burning antifreez in reply to Tractorboy, 06-10-2002 18:27:54
I guess you had better explain to an old farm boy like me how the pushrod tubes can let antifreeze into the combustion chambers. Be specific and tell exactly where the pushrod tubes would be leaking to allow fluid to enter the combustion chambers or intake.
He said there was no antifreeze in the oil so we know it isn't going there.
Joe (more)
06-10-2002 17:06:19
i forgot to mention that i checked the oil and it wasnt milky. the radiator cap only has water and antifreez on it.
gwh
06-10-2002 19:04:06
 Re: Re: My B started burning antifreez in reply to Joe (more), 06-10-2002 17:06:19
Remove the valve cover and snug down the cylinder head nuts, won't hurt anything unless you snap one off from tightening too much. I've got same problem w/ a 40 A , no time now to pull head found a loose nut, slowed down seepage until it gets a turn in the shop. I'm sure mine will need head gasket.
