2010 finally runs but woner if it will self distruct..
jay
06-11-2002 06:52:53
I finally got my 2010 to run but I had to change the plugs from H10s to H12s. I also put extenders on two cylinders. A mechanic friend said I could burn a hole in a piston. What should I do now?
Loren
06-13-2002 05:06:16
 Re: 2010 finally runs but woner if it will self distruct.. in reply to jay, 06-11-2002 06:52:53
I have seen a couple of your other posts but haven't followed them enough to know what all you have done to the tractor, so just ignore this suggestion if it is irrelevant. I had a lot of trouble with my 1010 when I first got it until I discovered the distributor was a mess. It still has a little play in the shaft but new points and condenser made a world of difference in how it started. I found my parts through NAPA which made the price more bearable than had I gone to J-D.
