1935 D fuel bowl
Marty Z
06-21-2002 01:01:06
My fuel bowl assembly is in bad shape and leaks.I have a spare bowl from my ford 8-N. It fits OK but I wonder about the fuel passage way being too small. Will this "D" pull too much fuel for this bowl to handle. Any Opinions? Should I try to buy a new bowl assembly? Thanks
Marty Z
Larry W.
06-21-2002 05:35:59
 Re: 1935 D fuel bowl in reply to Marty Z, 06-21-2002 01:01:06
Marty, What is it you are looking for? Send me a picture. Maybe I have something that will work. I have a spare brass crossover valve and more than likely the right sediment bowl. You can drive over and pick it up. We can go paddlefishing.
Clooney
06-21-2002 03:27:00
Marty, if it fits it should probably work.
~My guess is that if you installed that Ford strainer assembly & opened it up with a disconnected fuel line, all the fuel in the tank would drain out faster than your "D" could use the same amount of fuel..... .
