B carb confusion
need help
Jim M (RI)
06-23-2002 06:26:00
I have a "B" I just pruchased that the owner said the serial no is 159708. It has two fuel tanks, one for gas and the other for kerosene/ect. I took the carb off to inspect and rebuild and I am confused. On the bottom is stamped DLTX 7. In looking in section 110 of my service manual it says s/n 96000 - 201000 use DLTX 34, and above 201000 use DLTX 73 for "ALL FUEL" (which is what I thought I have) and DLTX 67 for gas. My confusion/questions are is there a DLTX 7 carb, or is this really a 73 (is that the way they stamped them)? Were the tractors with serial numbers 96000 - 201000 called "all fuel"? I am taking his word on the serial number as the plate is not legible. Is there any other way to determine if it is pre 201000 or post 201000. It is a hand start if that helps. Sorry for the long winded post, but I am trying to learn from info on the boards rather than trial and error. I read these EVERY DAY! Thanks for any help.
Jimm
Will P
06-24-2002 11:59:56
 Re: B carb confusion - need help in reply to Jim M (RI), 06-23-2002 06:26:00
You should have a DLTX34.
Will P
SEAMO
06-23-2002 09:13:48
Jim M. Look at your carb bowl again I think it will be DLT, not DLTX. I hope this helps Earl
Clooney
06-23-2002 09:07:31
third party image
Jim, this is a picture of a "D" carb but the position is about the same. ~As Ron said, you are probably looking at the bowl number.....
Ron Stephens
06-23-2002 09:00:36
The DLTX number will be cast or stamped opposite the choke lever. The number you are looking at is the casting number for the bowl.
