46 B fan shaft leak
Joe
06-23-2002 10:19:31
My fan shaft leaks out the front by the fan. over night there was a puddle about the size of a flat basket ball. how do i go about replacing this, and it also leaks around the governer end.
Pappy
06-23-2002 11:36:44
 Re: 46 B fan shaft leak in reply to Joe, 06-23-2002 10:19:31
There really should not be any oil in the fan shaft. The front bearing should be full of grease.
I would start by checking the ventilator system. It may be pushing oil up the shaft from the back. Check the tubes and see if something is clogged.
What tubes?/
06-23-2002 11:54:28
 Re: Re: 46 B fan shaft leak in reply to Pappy, 06-23-2002 11:36:44
there isnt any vent tubes on the shaft.
Jerry S
06-28-2002 12:21:46
 Re: Re: Re: 46 B fan shaft leak in reply to What tubes?/, 06-23-2002 11:54:28
There should be a vent tube I believe coming from the governor to the air intake piece prior to the carb. Check it for any obstructions.
