B Fan shaft leaks oil
Joe
06-24-2002 06:39:10
My fan leaks really bad out the front of the fan shaft, what parts will i need to order? how do i dissasemble? thanks
Slofr8
06-24-2002 18:43:43
 Re: B Fan shaft leaks oil in reply to Joe, 06-24-2002 06:39:10
Joe, I just changed the O-ring on the govenor end of my fan shaft ('43 B) but can't see how oil would get all the way to the fan. After dissasembly I couldn't figure out how to take the fan shaft apart and ran a "fan shaft" search on this board. Mr.Clooney has explained it much more clearly than I ever could. Even if this O-ring is not your problem I would change it while I'm this far. Local JD dealer ordered it, less than 4 bucks. The old one didn't even look like rubber, it looked more like greese and my leak was just a drip. Good Luck.
Eric
06-26-2002 19:54:22
 Re: Re: B Fan shaft leaks oil in reply to Slofr8, 06-24-2002 18:43:43
The fan shaft should have a felt seal at the end of the shaft.
