JD 50 Power Steering Hydraulic Valve Assembly
Joe Ashby
06-30-2002 21:34:37
There is a spring and a hydraulic valve spool behind the adjusting screw on the valve body which is adjacent to the worm gear (that connects to the steering shaft and wheel). Can anyone tell me if the spring goes in first, then the valve spool, or spool then spring? Also does the spool go in taper first or taper pointing out? Also does running the adjusting screw in decrease the hydraulic assist or increase? Right now it's pretty hard to steer. I have rebuilt the pump already. Thanks.
ChuckW
07-01-2002 05:11:12
 Re: JD 50 Power Steering Hydraulic Valve Assembly in reply to Joe Ashby, 06-30-2002 21:34:37
From experience I've found that rebuilding the pedistal has solved a lot of problem, have mostly found the vane seal badly worn and pins to the vane broken. Also careful attention needs to be paid to reversing the top gear to an unworn position. By the way all the PS valve units will work, the later models on 520/730's are more improved. The pedistals are different but the control unit is the same.
Clooney
07-01-2002 04:58:23
Joe, the spring goes in first [small end against the adjusting screw].
~I just had the steering valve housing off a P/S Deere a couple of weeks ago but can't remember which way that valve goes in, & don't have any manuals where I'm at now. [maybe someone will look & post it for you], if not look for a witness mark on the cap where the valve contacted the cap or a mark on the valve where the spring rode.
~The screw gets turned in to increase the assist pressure, if the ft. wheels start to oscillate [or flutter] back it off a little..... ..
