1020 wont start
Mark
07-01-2002 14:39:25
Ok I've got new plugs, wires, dist. cap, rotor, points, condensor and Rebuilt the carb. put in a new battery and tried to start it but it wont. I used starting fluid and that helps a little but still wont start. This thing has good spark and is getting fuel. one thing that I noticed is that this is sucking air through the exhaust manifold. i tried to narrow it down to one cylinder and found that all of them are doing it equally. You can hold your hand over the exhaust manifold outlet and while cranking you can feel it suck in then blow out. What is going on here is it supposed to do this? I have never known an engine to do this. Is the cam out of time with the crankshaft? Possible jumped a tooth on the timing chain\gear? It acts like it wants to start but doesn't. HELP I'm going nuts with this thing.
I have tried to line up the crank/valves/distributor and it looks ok I think.
JDM Guy
07-01-2002 15:19:12
 Re: 1020 wont start in reply to Mark, 07-01-2002 14:39:25
Like Richard said its got to be timeing. I don't know alot about the 1020 but I know engines. If the exhaust manifold is only for exhaust and not carbration then you have bad timed valves or bad valves. Try putting your finger over the spark plug hole and cranking it when you feel the conpression stroke look at the plug and if it sparks at the same time you feel compression then you know the timing is right. Check all the cylinders for this. Just my 2 cents.
Richard
07-01-2002 14:56:13
I think you've diagnosed it. Has to be the timing.
Mark
07-01-2002 18:00:54
 Re: Re: 1020 wont start in reply to Richard, 07-01-2002 14:56:13
I have removed the water pump and the timing gear cover. There are 5 gears in there total. It looks like center of the five gears is the crank and the two above it are for the cam. Does anyone know which marks to line up for correct timing?
I wouldn't have to ask except the new manual isn't here yet.
Also what are the lower gears for? oil pump maybe?
And governer?
Thanks
Mark
