1947 Model M Stops Running
Glen Webb
07-03-2002 15:46:59
After running for a short while, and before getting to operating temp, my M starts to miss and eventually stops running.
Last year I replaced the coil and condensor. It was stalling out very similiarly when hot.
Thanks for any advice.
Glen Webb
JDM Guy
07-04-2002 04:25:58
 Re: 1947 Model M Stops Running in reply to Glen Webb, 07-03-2002 15:46:59
Had the same problem with an M and a MT. I ended up replacing the coil, condensor, rotor and spark plug wires. Also it could be fuel flow. I remember when my M had a pluged sedement bowl. It would fill up over night and when I started it would run great for 5 minutes then once it was hot it would stall like yours. After an hour or so it would run again. Ended up just clean out my sediment bowl and that was that.
Bus Driver
07-03-2002 18:10:14
I suspect that the condensor has failed again. The other thing to check is for good fuel flow. The drain petcock in the bottom of the carburetor is the best place for this check.
