Model B 3 point still not working!!!!
Joe
07-07-2002 18:14:52
I took my power trol off again to check every thing and it was fine.i have a question about the valve that is held in by the spring, should the valve seat? because mine isnt seating, theres about an 1/8 in gap from seating. but thats how it was before, and it worked before replacing the gaskets. if you pull up on the lift arms, and hold it there for a while, it will stay strongly up, and it will go down when pushing the handle back, what the HEL* is going on!!!!! im sick of this!
thanks
Joe
News Boy
07-08-2002 15:24:19
 Re: Model B 3 point still not working!!!! in reply to Joe, 07-07-2002 18:14:52
Try the classifieds !!!!! !!!!! !!!!! !
JDJACK
07-07-2002 19:52:29
Joe, what did you do to it last that it won't work? Did you try and hook a remote cylinder to see if it works? Do you have the dummy plug in the correct hole? I believe that you only need one dummy plug.
Joe
07-07-2002 20:00:23
 Re: Re: Model B 3 point still not working!!!! in reply to JDJACK, 07-07-2002 19:52:29
I replaced the piston seal,and the pto seals, thats all that ive done, didnt mess with anything else.
JD JACK
07-08-2002 05:03:08
 Re: Re: Re: Model B 3 point still not working!!!! in reply to Joe, 07-07-2002 20:00:23
Did you use a new gaskets, and was the gasket installed correctly for piston cylinder? Have you tried to use a remote cylinder?
Clooney
07-07-2002 18:47:07
Joe, does the pump make any noise when you put it in the lift mode?
~Did you match the old & new gaskets up to be sure they are the same?
~Maybe you have some dirt caught in the relief valve.
~You weren't real specific about which valve, but it sounds like you are talking about the "throttle valve". That valve controls the lowering rate & is usually adjusted to be slightly off it's seat to allow the rockshaft to lower. The more it's open the quicker the rockshaft lowers..
Joe
07-07-2002 18:49:10
 Re: Re: Model B 3 point still not working!!!! in reply to Clooney, 07-07-2002 18:47:07
It doesnt make noise, i am talking about the valve that can be taken out. but still, why doesnt it even make noise?
Clooney
07-07-2002 19:05:43
 Re: Re: Re: Model B 3 point still not working!!!! in reply to Joe, 07-07-2002 18:49:10
Joe, it probably isn't making noise because it either isn't getting oil to the intake or there isn't any pressure to the control system due to a stuck relief valve, inoperative operating valve, misadjusted linkage, internal leak or?
~Pull the little top cover & see if the valves are operating when you move the lever.
~ If they are, you are probably going to have to put a pressure gage on it to see if it is making any pressure..... .
MORE
07-07-2002 18:16:53
there is oil in the gears and the pto is turning, it is a 1946. I do have the correct dummy plugs in it.
