MY 3 POINT STILL DONT WORK!!!! AHHHHHHH!, but.....
Joe
07-09-2002 12:23:33
i took the power trol off again for the thousandth time, and when i turn the pto shaft oil comes up from the pump, so i know the pto pump gears are working, and still when i lift up on the lift arms then let go, it stays up strong, and when you push the handle back, it goes down. the hydrolic fluid is full. it doesnt make any noise when you push the lever forward, just as if the pto wasnt running, but it is and the darn thang still dont work. this is a 1946 B
Clooney
07-09-2002 13:36:03
 Re: MY 3 POINT STILL DONT WORK!!!! AHHHHHHH!, but..... in reply to Joe, 07-09-2002 12:23:33
Joe, pull the relief valve out & look for something caught in it. If it's stuck open you won't make any pressure.
~It sounds like the control valve is at least partially working due to the fact the 3-point will stay up if you lift it up & will lower when you move the handle
~My money is on a [stuck open] relief valve..... ...
Joe
07-09-2002 14:58:45
 Re: Re: MY 3 POINT STILL DONT WORK!!!! AHHHHHHH!, but..... in reply to Clooney, 07-09-2002 13:36:03
Which valve is that? do you have a picture? the one with the spring that comes out when you pull the power trol off?
Clooney
07-09-2002 15:15:26
 Re: Re: Re: MY 3 POINT STILL DONT WORK!!!! AHHHHHHH!, but..... in reply to Joe, 07-09-2002 14:58:45
Joe, E-Mail me your E-Mail address & I will send you a picture..... .
