Still not working(clooney)
Joe
07-09-2002 19:03:16
I spun the pto and the valve came out, i guess it wasnt stuck. What is going on? i cant figure it out! so we know that oil is coming to that valve, but why isnt it making it to the clyinder?
Clooney
07-10-2002 03:36:54
 Re: Still not working(clooney) in reply to Joe, 07-09-2002 19:03:16
Joe, you are getting to the point of frustration. ~I really don't know what else to tell you to try. If I were working on that unit I would put a pressure gage with shut-off valve across the remote ports to see if I was actually getting pressure from the pump. Just because it pushes a little oil at slow PTO speeds doesn't mean it is pumping oil with any pressure behind it when running.
~Did you take ANY other bolts or caps out of the power-trol valve housing during removal [even for a second or by mistake? [if so which ones]
~Are both the round & square hole between the valve housing & rear housing open & not blocked by the gasket?
~Did you put the pump gears back in the same way they were removed [one didn’t get flipped over did it?
~Is the pump gear drive key [positively] between the PTO shaft & the pump gear?
~Was the pump housing worn? If so did it get put back in the exact same place?
Joe
07-10-2002 07:44:57
 Re: Re: Still not working(clooney) in reply to Clooney, 07-10-2002 03:36:54
Im just as confused and mad as you, but when i took it off, all i did was replace gaskets.i took the pump gears out just to replace the old gasket but that was it. i didnt even touch the power trol. i only have a engine compressor tester. Will that work or where can i get one for testing oil pressure? what should it put out? sorry for all you trouble.
Clooney
07-10-2002 16:24:02
 Re: Re: Re: Still not working(clooney) in reply to Joe, 07-10-2002 07:44:57
Joe, you will probably need at least a 1000 lb gage & a 1500-2000 would give you a safety margin.
~You will need to install a pair of remote adapters then rig a hydraulic hose with the gage in it, place a high pressure shut off valve in the line between the gage & the upper outlet then once it is running at fast idle move the operating lever to the raise position, then slowly close the valve & watch the pressure, it should climb to 750-1000 lbs. If it doesn't either your pump in N/G, the operating valve is malfunctioning, the pressure regulator is malfunctioning, or there is an internal leak.
~You could probably do a quick test just to see if the pump is making pressure by installing a single remote adapter in the upper outlet, then plugging it off with a pipe plug, then running the tractor & moving the lever to the raise position [if the pump is making pressure you should hear the pump moan, & the pressure relief valve open & make hissing or buzzing a noise]
