3 point works, but lifts slow
Joe
07-10-2002 18:04:53
I found the problem, the key that kolds the gear on the shaft was in pieces and smashed, put a new one on and it works, but lifts slow, i messed with the metering screw and i wonder how you go about making it lift faster? thanks for all your help.
Ed T.
07-12-2002 05:11:00
 Re: 3 point works, but lifts slow in reply to Joe, 07-10-2002 18:04:53
Slow Lifting can be caused by water in your hyd. oil. This also causes jerky lifts.
Tractorboy
07-10-2002 18:53:37
Now where did all that metal from the key thatwas smashed go ? Right in the system and plugged it all up . It dont take much .
Clooney
07-10-2002 18:47:52
Joe, the metering screw only effects the slow raise. It shouldn't effect the fast lift position.
~If the control lever or valve isn't [or wasn't] going to full fast lift you might be restricted somewhat by the metering screw. [turn the metering screw in to increase the slow raise speed].
~If that isn't the problem you might need to give it time to bleed all the air out of the system.....
